Thread: EasyTouch programming help
    Dec 2013
    Northridge, CA
    29
    Hey all -
    I've got everything set up and connected. 2 Pentair pumps, actuators on the intake & return side to switch between Pool & Spa mode.
    I can go to Pool mode, actuators work as expected, and circulation works great, with some going back to the spa through a check valve for the spillway.
    Spa mode works as well, kicking on pump #2 and moving the actuators to the spa side.
    I want to set up a feature called "Water Features" which will:
    1) turn the actuators to pool side
    2) kick on the booster pump
    I got part 2 just fine, but I can't seem to figure out how to make sure #1 happens. I don't see anywhere during Feature setup to configure what "mode" the pool is in to handle the actuators.
    Help please!
    Re: EasyTouch programming help
    I don't think you can do exactly what you are asking for. If you assign the booster pump as a pool cleaner it won't run when in spa mode, but I don't think you can get it to switch to pool mode when you press the button.
    Dec 2013
    Northridge, CA
    29
    Is there a way to set up an Aux or Feature that will change the direction of the Intake/Return valves?
