Results 1 to 17 of 17
Thread: Storing Vac Hose -- recommendations?
    I'd like to get a hose reel. I see one that is a cart with wheels and other reels without wheels. I don't want something that is flimsy that will break or be more of a hassle to use than rolling the hose by hand.
    The hose will likely be kept out of storage, in the sun sometimes. I don't think the reel will fit in the Suncast storage area where I used to wind the vac hose around some large tubs of chemicals.
    Does anyone have any warnings of brands they were unhappy with, or suggestions of a brand they liked?
    I do not want to make one of PVC, I really want one that unrolls the hose so that it does not kink.
    Advice?
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,113
    Re: Storing Vac Hose -- recommendations?
    We found a large trash can with lid works best for us. Easy to coil and uncoil, hides easily, and keeps the hose out of the sun.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    I use a trash can as well...........with wheels on it.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Mine just goes in the large deck box along with the nozzles and brooms. Handy and out of sight.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Quote Originally Posted by steveg_nh View Post
    Eh, been doing that, but I'm finding that not sufficient. Maybe now that the Polaris is running so well, we won't need that hose out much and it can go back where it had been, wound around a bucket of Cal-hypo or whatever in the storage box way around the corner.
    I was hoping that someone had a favorite product that they used to roll the hose up and cart away neatly without having to wind up and fight to unwind later. Guess I'll just blindly try one, after I resolve whether it will fit back into the bin.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Out of curiosity, I Googled "Pool hose Reels"
    http://www.recreonics.com/vacuum_hoses_reel.htm
    $1394.25 for this little reel !!
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Quote Originally Posted by anonapersona View Post
    Probably why it works for me. Hardly use the hose vac with the Polaris. The robot works amazing!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Thats just crazy! Spend 1400 dollars to store a 35 dollar hose. And it aint even chromed! smh
    Quote Originally Posted by Willi View Post
    Excellent idea. Thanks woody!
    Quote Originally Posted by woodyp View Post
    Divin Dave,
    Hi. I am also looking for a storage solution. A trash can sounds good. But what about any moisture inside the hose?
    Intex Ultra Frame 18'x52"
    Intex 2650 Sand Pump
    Krystal Klear SWG
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Quote Originally Posted by brightblonde View Post
    I use a trash can as well, I put a couple of holes in the bottom to let water drain out, I also keep the vac head & skimmer plate in it also
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    On some of the cleaners if you read the manual, they say to lay the hose straight/flat and do no leave coiled up.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I hang it from a hook under the deck stairs. I hardly use it. Most pool vac'ing is handled by the Polaris.
    Thanks for the suggestions.
    Does the hose need to be kept out of the sun?
    Krystal Klear SWG
    Pool Cleaner & Vacuum Storage Hose Reel - PoolSupplies.com
    Haven't ordered one yet myself but thinking about it
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Certainly not a bad idea to keep it out of the sun. After a while, the sun will ruin anything.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I use a FeherGuard FG-VHG reel. Works pretty well.
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
