Results 1 to 7 of 7
Thread: Pool collapse - new pool options
    Two years ago we bought a house with a 27' round Ester Williams pool which had been buried except for about a foot. Hard to tell exactly since there was a deck around it. The previous owner gave us paper where he had replaced the liner about 2-3 years before we bought the house. The original pool was installed in the late 90's by the same group that we had bought our first pool from. Last fall before we were getting ready to close the pool we got a large rip in the cove area. We tried to patch and keep water in the pool. We had the guy who had replaced the liner come out to patch it. He didn't bring his stuff with him. Mistake 1 on his part. Mistake 2 he told me that even though the pool is dug out in the center he didn't put any special liner in it. Now I understand they will stretch but all 2 seasons we swam the liner at the top was bubbled with air between the wall and liner all the way around. So I don't think the install was right or something here. Mistake 3 was he told me that the reason he had to replace the liner before was because of a hole in the same place and that there had been a cave in that very spot. So all the things and the fact that he never returned to patch the pool as he said he would made me very leary of him. So now thus year we actually had a real winter and lots of rain. We lost the battle with the leak and it caved in.
    We are now investigating options. A true in ground really isn't in the budget. I've researched here on the semi inground options and have narrowed it to the king george, bermuda or doughboy palm shore. The plumbing was already hard plumbed. We would really like to switch to an 18x34 52" oval with a hopper end. The walls on the orig pool are 51". My concern though here is the disturbed ground that the walls would now be sitting on. Are we asking for trouble down the road? Would a better option be to go with a larger round pool and still have a hopper side?
    We are also having issues finding an installer here to work on it. Was wondering if anyone on here knew any installers in the Memphis Tn area? Hubby and I are diy'ers but we are not to sure about this project. We have already started the demo. Pool is out and now he has to remove the decking. We didn't like the decking anyway and now that we see the structure underneath we really don't like it
    There is one doughboy dealer here who we talked to Saturday. However the main doughboy expert wasn't in.
    Here's a pic of our hole to help with the visual.
    Sorry for the upside down pic. Posted using iPad.
    Above Ground 30ft x 4.5 ft deep, vinyl liner, hayward 1.5hp sand filter
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Re: Pool collapse - new pool options
    I have to fix it. Too much blood flow into my head when I'm upside down
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    No suggestions or recommendations from the experienced pool people here?
    Pysiek's Avatar
    Apr 2012
    419
    I'm not experienced pool guy but make my pool guy told me not to put more then 2 in of sand under my pool and not less then 1". And also he told me not to install the pool wall uprights on the sand but on the virgin soil.
    May 2013
    Albany, NY
    59
    I'd certainly be concerned with installing on disturbed ground, especially considering your previous cave-in issues. Have you considered a round pool with a larger diameter that would be able to rest on virgin soil?
    Eric Adams, Technical Specialist, Radiant Pools
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    You could maybe lay a concrete base then put some padding like foam underneath your pool....? That would give you a better foundation, and it will make your pool be level within 1/2" if its done right...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2014
    Thomson GA
    166
    I am not a pool expert by I think someone could pour concrete footings under the uprights and reuse the hole. Although I think the deck will have to deck boards would have to be removes to allow room to work. Just my $.02.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
