Results 1 to 9 of 9
Thread: cracked shotcrete
    cracked shotcrete
    I had my pool dug and sprayed with shotcrete last fall. We have developed a long crack in the deep end. I talked to the builder and he states this is common with shotcrete and won't effect the integrity of the structure. I've searched online and have seen differing opinions. Anyone have input on this?
    Re: cracked shotcrete
    Sounds like a structural crack. Can you give a better description of the crack? Pictures would also be helpful.
    Can you describe the soil, and if they hit water?
    What were the specs on the concrete thickness, psi and rebar?
    Do the crcracks go up the walls and through the tile?
    Support the site
    Very fine cracks that don't go very deep are common, while deeper cracks indicate a problem. Unfortunately it is tricky to describe how to tell the difference in words.
    For some reason it didn't let me upload the picture. I've linked to it in imgur, if that works.
    That looks like a structural crack. It's hard to say if it will be ok long term. I would be wondering why it cracked now.
    Why hasn't the pool been plastered by now?
    What is your ground-water situation?
    Support the site
    Mar 2014
    Imperial, CA
    70
    I'm no concrete expert, but the crack looks like it has water seeping up and through it. That would make me think the crack was structural and not just a surface crack. That would be my concern if it were mine. Remember I don't know anything about concrete, maybe someone with some experience or expertise can correct or confirm that suspicion.
    IG shotcrete 32' x 16' rectangular pool; 3 1/2'-6'-4.5' depth.
    Hayward Aqua Rite 40k swg, Stonescapes mini pebble Aqua Cool, auto fill, Pentair intellibrite colored light 12v, Travertine coping, Pentair intelliflo variable speed pump, Pentair 60sf FNS plus DE filter. TF 100 test kit.
    Very hard to say if it is structural, but it is rather straight which makes me think its got more to do with poor concrete cover over a pipe or reo.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    The only way to know for sure is to have a section cut out say a 4 x 8 inch to see how deep it goes down .
    A concrete patch can repair that part.
    Since it is side to side it does appear that the weight of the deep end and or the ground underneath settled during the winter.
    Over all it does not look fatal, but if you plaster on top and it settles any more you will have a crack in your plaster.
    To the above posts - how is the structure of the rebar, thickness of the gunite and what kind of base was under the gunite if any.
    Also do you have water under the pour. My pool actually has a natural water running under it - its just how the site was....
    In New England or CT we over engineer our pools with rebar and spray 12" thick gunite all the way around. Many builder use thinner or 8" gunite and
    then will make a T or a cap on the walls at 12" for coping. We spend an extra 2- $2,500K on base gravel, steel and gunite, but even my pool has a small
    hairline crack.
    I can't fault your pool builder, but it should be checked out before you spend a lot of money on the finish.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    IT it wasnt there before, I would imagine a timely repair and refill would be in order....otherwise, it's safe to assume it'll get worse.
    15 K gal/gunnite, 600 gal attached SPA, Hayward: ProLogic, ColorLogic LED, Super II pumps, 400k BTU heater, StarClear cartridge filter for, SwimClear cartridge filter . Pentaire: booster
    http://www.troublefreepool.com/detai...l?hilit=corpus
