Thread: Need advice...filling a hole that will be under the pool
    Jul 2013
    Princeton, NJ
    26
    Hey folks,
    So i had an old clothes line pole sunk in the ground about 2 feet with concrete. I yanked it out with my truck and used it as a fire pit for about a year.
    Now, I'm needing to fill it in as I level the ground for the pool.
    Any thoughts on the best way to fill it in? My cousin mentioned rocks and sand and douse it with water to move the sand down into all the cracks.
    Thanks!
    damon
    Apr 2014
    KY
    4
    Re: Need advice...filling a hole that will be under the pool
    I was in a similar situation with an old fence post I pulled. It was at the corner of a drive way. It was a wooden post about 8 inches in diameter and 3 feet in the ground. I tried filling it in with dirt and bricks but it would continually sink in. If it wouldn't cause any issues with the pool, I think I'd fill it to with in about 6 inches or so of the top with concrete, then put sand or dirt on top of the concrete.
    30,414
    Clean out all the disturbed soil and fill the hole with clean rock. Most common here is #57 rock which varies but is maybe 1-1.5 inch in diameter.
    It will not compact........ no sand necessary
    Mar 2014
    Thomson GA
    166
    Fill it with sakrete to a couple of inches below the bottom of the pool floor.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
