Thread: DIY build - Help with cutting holes in steel wall panel
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    We bought our the basic kit from Royal but chose to get our equipment from other sources and saved a bunch. However, because we didn't buy our lights from Royal, they wouldn't send us "light" panels. Now we need to determine what's the best way to cut the hole for the light niches. We've got the template that came with the niche. Have any of you had to do this? Any tips and suggestions would be greatly appreciated.
    Jan
    Coming in Spring 2014: Semi DIY 18'x36' rectangular 2' radius ig steel wall vinyl; 3.5'-8'; NO main drain, 2 skimmers, dedicated cleaner line, 5 returns (2 surface, 1 low in deep end, 2 in steps,); 1hp Pentair Whisperflo 2-speed pump; Pentair Clean & Clear 420 cartridge filter; Intellichlor IC40 swg; Raypak Digital NG 399K Heater; (2) Pentair Intellibrite LEDs, 2 wheel Poolvergvegen ; S.R. Smith Salt System diving board
    Mar 2014
    Canada
    14
    Re: DIY build - Help with cutting holes in steel wall panel
    I never order light cut outs with my kits. Gives you more freedom on light placement. The appropriate sized hole saw or a jig saw will do the trick.
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Thanks OntarioPoolGuy... Looks like hubby gets to buy some new tools !!
