Thread: Older Aquapure, having trouble figuring out troubleshooting?
    Apr 2014
    Georgia
    11
    I bought this house a couple years ago and have been replacing the pool components as they are all towards the end of their service life I think. I am good at electronic trouble shooting if I have the right manual.
    Everything I have found on the newer Aquapure 1400 shows front board / back board, and none of them look like this. Is this a prior generation?
    This is a great document, but none of the pics/diagrams look like my setup
    https://www.inyopools.com/manuals/16...rror-codes.pdf
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Older Aquapure, having trouble figuring out troubleshooting?
    Welcome to TFP!
    You have an Aquapure with a metal power center as opposed to the plastic. Either way, most of the testing in the document you linked to is still valid, from error codes to test points, although they may be in different locations.
    Your board looks like part number R0467600. Here's the deal...as much as I like my setup, the Aquapure can be finicky. They are prone to throwing error codes reporting one issue but are caused by something else. If you can determine the board is ok, I would put money on the tri sensor.
    I would test the board, clean your cell and sensor, double check and clean up all the connections and see what happens. By the way, how old is your cell and sensor? Original? Your power center started being made early 2008.
    That is a place to start. Post a pic of the cell and the sensor face if you can.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Also, this guide will help. It has specific test instructions for your model.
    Oct 2007
    Parkland, FL
    752
    I know this is old, but that guide helped me today. I had the older guide which wasn't much help
    Do you still have that guide? Link to guide does not work
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
