Thread: Help Replacing Intex Liner
    Apr 2014
    Broken Arrow Oklahoma
    2
    We have a 22 x 52 ultra frame pool that is all of a sudden got multiple holes and the liner itself seems very brittle? Would you recommend using the overlap liner for a replacement since Intex seems to never have any in stock and you can't even get them to respond to anything in reference to the liner. We don't really feel like spending 700 again on a new pool. Any written explanation to us would be greatly appreciated.
    New Post created. Please make a new post for better response when asking your own question. Brushpup
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help Replacing Intex Liner
    Welcome to TFP!
    Sorry I don't know, but others may be able to advise you better. If it's brittle, I'm not sure it would be any good.
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Intex liners are available, or were when we needed one for our pool. We couldn't get it from Intex, however there are several places online that have them.
    That being said, what part of yours is brittle? is it just the floor? Or are the sides getting that way as well? If the sides are ok, you should be able to use an overlap liner.
    If you go with an overlap, 62" or longer sidewalls would be a good idea. Secure it to the outside of your old liner with rope and these:
    http://www.harborfreight.com/15-piec...ack-93740.html
    Apr 2014
    2
    We have been searching for weeks to order a new liner and can't find one anywhere on line. Intex is out of stock and has been the whole time and its mostly the bottom that seems brittle but regardless we just want to replace the liner.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I'm Australian and I think you can get them from here.... It might cost a bit in postage though.... http://idealshop.com.au/c/intex_and_...are_parts/64//
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    You can type in the search on this forum for "Installing replacement liner intex". I replaced mine with an overlapping liner two years ago and it's still up today. I haven't been on the forum for some time so will update the thread when I get the solar cover off. I thought there were more pictures on the thread but for some reason some are not there. The thread shows the tie offs like Charlie_R mentioned above.
