Thread: which timer for my pool
    Feb 2014
    oklahoma
    45
    so i am new to pool timers. I am having a 17k gallon fiberglass pool installed. I am going to have a 2 speed jandy pool pump 1hp. I will have a sand filter and a suction side cleaner with a circupool swg. any suggestions on what we should put for our timer?
    38,539
    Re: which timer for my pool
    What do you want the timer to do? Just turn the pump on and off or also switch the speeds?
    Feb 2014
    oklahoma
    45
    i think just on and off. i would think the only time i will run on high will be when putting in chemicals or running the cleaner.
    38,539
    I agree. Can't go wrong with the mechanical Intermatic timers. Just get the 230v version (I assume it is hardwired pump at that voltage? ) And it should supply power to the pump and SWG.
