Thread: Pool antifreeze - get rid of during pool opening?
    Jun 2013
    Boston, MA
    91
    Hi,
    Per instructions I learned from this board (awesome) I put pool anti-freeze into the skimmers and pipes. I know it's supposed to be safe and all, but I'm OCD. Is there anyway I can get rid of most, if not all, of the anti-freeze during startup? Is it safe to run the pump/filter on Backwash during the first start-up of the year?
    Thanks
    Inground pool; about 20,000 gallons (18' x 36'); pool liner (vinyl?) a few years old; Hayward pump SPX2607X10
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Pool antifreeze - get rid of during pool opening?
    Would a wet/dry shop vac suck it through? Or blow it from the skimmer out the open pump strainer?
    Starting up on backwash is alright, though there is no need for it.
