Thread: Just took cover off pool! Thanks BBB! Crystal clear
    Jul 2013
    Perry GA
    6
    Red face Just took cover off pool! Thanks BBB! Crystal clear
    Attachment 28362
    Installed 18' Doughboy last May. Used BBB all summer long. Covered in September. Removed cover today.
    Picture speaks for itself.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Just took cover off pool! Thanks BBB! Crystal clear
    Beautiful and sparkly!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Casey's Avatar
    SW PA
    10,448
    Your pool looks fantastic! Congratulations! I experienced the same as you! I pulled the cover off on 4/10!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Wow, both pools look amazing... I can't wait to leave my pool up and try this next year...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    That right there is a great testament to BBB, TFP, or whatever acronym you want to call it.
    Divin Dave,
