Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Yikes. Opening after winter.
    Apr 2013
    NE Oklahoma
    53
    I'm sure not looking forward to cleaning the 3 feet of murky mess that is my pool in order to open it in a couple weeks. Maybe you will have some tips to make it easier?
    The cover got blown into it and frozen. And frankly, I sorta hibernate for winter. Today was maybe the second or third time I even looked at it since I closed it up last October.
    Also, is there some machine I can set in it to clean it or maintain it's cleaning? I'd pay up to $300 IF such a contraption is deemed worth it.
    M
    Newbie to pool ownership.
    5000 gallons
    Intex Krystal Clear sand filter pump 16" & saltwater system model CS20110
    AG Intex 16' x 48" Ultra Frame
    Leslie Chlorine FAS-DPD Service Test Kit
    Casey's Avatar
    SW PA
    10,448
    Re: Yikes. Opening after winter.
    Pool School. Everything you need to know is in Pool School.
    38,343
    You just need to scoop as much gunk out as you can. Circulate for an hour. Test at least the pH and CYA. Adjust if needed. And then follow the SLAM Process.
    Shoot, if you lived near me, I would clean it up for $300
    Casey's Avatar
    SW PA
    10,448
    275 here!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Hmmmmmm....very tempting!!
    only a few hours drive, might take a day or three.......
    Aug 2011
    Cochranville, PA
    228
    How about drain, scrub and fresh fill.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Quote Originally Posted by JustThe12OfUs View Post
    Kids. If you dont have any, then the next best thing is a pool cleaning party. One of my friends does it every year. Buy a couple more nets, some "refreshments" and a bunch of porkchops or pizza.
    If you dont have any friends either, then it might be rough going getting all the muck out.
    Divin Dave,
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,097
    With your pool being 5000 gallons, I'd second a vote for a drain/refill. You may need to reset the liner some, but in the long run I'd expect this to be cheaper/quicker than the Slam process.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Another vote for a drain and start over.
    Jeff
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    That's three for drain and refill
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Aug 2011
    Cochranville, PA
    228
    Get what you can out with a net and drain. Then go in with a hose, brush and bleach. Don't forget to check the liner as you fill for wrinkles. I forgot and had foot prints all season.
    Apr 2013
    NE Oklahoma
    53
    I'm voting for drain and restart simply because it's faster.
    Thanks!
    M
    5000 gallons
    I agree drain and refill. Sounds like the cheapest option.
    24' round AGP 17Kgal. TF 100, BBB method all the way
    Apr 2013
    NE Oklahoma
    53
    Alright. I drained and refilled and everything is up and running. I seem to be having a problem getting my FC and CYA Levels up to where they should be. I poured in the amounts suggested with the pool chem table according to the numbers from my testing and they are staying 0 and <30?
    Obviously I could just keep adding more of both, but I thought I'd double check to see if there could be some other problem I'm missing?
    FC 0
    PH 7.2
    CYA <30
    TA 70
    I put those in the calculator and it tells me to add bleach and CYA, I do that, then check it again in the am and the numbers are the same. Pump is working fine as far as I can tell... It's still too cold to swim in for more an a few minutes if that makes a huge difference. I do remember that at initial set up last year I felt like I used a lot of bleach at first...
    M
    5000 gallons
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    CYA will not show up on the test for about a week. You know what your target is, and once you have added that to the pool, bring your FC to the appropriate level for the target CYA.
    Apr 2013
    NE Oklahoma
    53
    Quote Originally Posted by Charlie_R View Post
    Ohhhhh. Okay. Well toot. I don't think I added too much CYA... But I should keep adding bleach until it comes up, right?
    So glad I checked in after adding twice. I usually don't put in as much liquid CYA as the calculator says so I think that paid off.
    Thanks!
    M
    5000 gallons
    Casey's Avatar
    SW PA
    10,448
    Why are you not hitting your target? You're using the pool math right? You're shooting for 4ppm FC right?
    Apr 2013
    NE Oklahoma
    53
    Yep. And that's why I came here. I have no idea why I'm not hitting target on the chlorine. I understand, now, why the CYA hasn't changed yet, but not the chlorine.
    M
    5000 gallons
    Casey's Avatar
    SW PA
    10,448
    What test kit you using? Do you have CC's?
  20. Back To Top    #20
    Apr 2013
    NE Oklahoma
    53
    No mater what, it comes up clear in the testing. FC, Tc, CC
    Weird. My CYA isn't showing up yet either.
    The water is crystal clear. The pump seems to be working fine. I switched it to boost.
    But I can't get the chlorine up? I guess I could just keep adding and adding more?
    My Ph went up to 7.4
    M
    5000 gallons
