Thread: Tri Sensor Adaptor AquaPure w/jumper?
    Apr 2014
    Medford NJ
    3
    I replaced the cell on my on older APure 700.
    I have actually done this several times.
    The new cell came with a Tri-Sensor adaptor and a cable assembly.
    My question is what do I do with little jumper on the adaptor, no where in the instructions does it say if should use the jumper or not!
    Thanks for any help and all help
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Tri Sensor Adaptor AquaPure w/jumper?
    Welcome to TFP!
    Just to confirm, you purchased a cell replacement kit that contained the cell, power cable, tri-sensor (with a sensor adapter board attached)? The use of the board jumper is dependent on the firmware version of the controller. Most likely you will need to use it. They may not have given you the instructions since it was part of a kit.
    See page one of this document to check if you need it. I hope that answers it for you.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Apr 2014
    Medford NJ
    3
    Quote Originally Posted by UN1017 View Post
    Welcome to TFP!
    On page 3 figure 5 it shows the little jumper installed.
    The jumper was taped to the wires, but not installed.
    Maybe I've just missed it, but I can find nothing in the instructions on using this jumper.
    Thanks
    Apr 2014
    Medford NJ
    3
    On re-reading carefully I found it.
    Thanks for your help!!!
