Results 1 to 10 of 10
Thread: Opening numbers....am I doing this right?
    Jul 2012
    Forest, VA
    79
    Ok so I opened my pool 2 days ago to find a quite lovely shade of green slime on the sides and bottom. I brushed as much as I could see. I added 16oz of 3% copper algaecide and ran the pump in recirculate for 18 hours. Pool is now mostly blue but very cloudy. I did my initial tests...
    FC no surprise 0
    CYA under 30
    Alkalinity 50
    pH above 8
    With the CYA being below 30 I added 2x 1lb bags of dichlor shock in hopes to bring CYA up a little and get the FC up.
    Also added 1/2 jug of muriatic acid to bring pH down and baking soda for the alkalinity.
    Retested today and numbers are as follows:
    FC 7.5
    CC 0
    CYA 55
    pH 7.0-7.1
    Alka 65
    I will not add anymore dichlor seeing that my CYA is 55. I will only use clorox from now on.
    I just added about a jug and a half of clorox ~150-160oz. per the math calc to bring FC to shock level of 20.
    Am I headed in the right direction? Do I needed to flock the pool for the cloudiness or just let the filter take care of it?
    Thanks in advance for the replies.
    Tommy
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Opening numbers....am I doing this right?
    Floc doesn't always work like you would expect it to.
    You should be running your pump 24/7, and keeping your FC at appropriate SLAM levels until you can pass the OCLT. Clear water is one of the parameters for passing this.
    Your filter will take care of the cloudiness, if you let it.
    Jul 2012
    Forest, VA
    79
    Also another question.....does DPD powder go bad? I have a small container and its turning black. I bought a new one but would like to use the old one if I can.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    It still works. I bought my last refill just before end of season last year, and since I don't have a humidity controlled environment, it too is turning a bit dark. Still works just fine though.
    30,402
    The test for whether it is bad or not is easy enough.
    Assuming you have some chlorine in your pool, just put the powder (same quantity as always) in the test vial and stir/shake/spin. If it turns pink like it normally does, the powder is good.
    It really kills my refill sales to admit but it is most always good for the two seasons that covers the guaranty.
    Jul 2012
    Forest, VA
    79
    Thanks for the advice!
    Sep 2013
    Terre Haute, IN
    36
    Quote Originally Posted by tadcpht View Post
    Since you asked if you are doing this right....
    No, you did not need to add any copper to your pool.
    It can be a preventative but if I have read pool school properly it is not an effective algae killer.
    Copper can also cause staining and/or green hair issues.
    Just need to keep it in mind in case you have any issues in the future and to discontinue use.
    Copper Algaecides are not typically recommended around here.
    33,000 gal Inground Vinyl Liner
    Hayward Sand Filter
    2 skimmers
    2 returns
    1 vacuum line
    1 main drain
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by aldrichg9 View Post
    This.
    I haven't used an algaecide, of any kind, in the last two years.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've never used an algaecide either. Keeping the FC in the proper range for the CYA level is all the algae preventer you need.
    Jeff
    Oct 2013
    Chapin, SC
    1,141
    2lbs of dichlor will add at most 13 ppm cya. It will also raise your fc 15ppm in your 9000 gal pool. What or who are you using to test your cya and your other levels. What percent chlorox?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
