Results 1 to 9 of 9
Thread: New pool - startup next week - questions
    Feb 2008
    Princeton, NJ
    46
    Hi All,
    our new pool will hopefully be ready on Sunday - plaster day ! We are in Princeton, NJ, and the temperature is currently in the high 80s - low 90s.
    It's a 24K gallon inground freeform pool with 3m quartz finish, Jandy chlorine generator, IntelliFlo pump, Jandy PDA-PS8 controller, 6' sheer descent, Heliocol solar heat
    I am looking for some help for the first weeks. I have successfully used BBB for two years on my last vinyl pool but this time it's a bit different ...
    The TF100 test kit is on the way ...
    Here is what I understand we'll need to do:
    - once the pool is full (60% trucked in, the rest from a tap) we'll run the pump 24 hours
    - brush twice a day for two weeks
    - carefully monitor the PH daily and adjust if necessary with muriatic acid or Borax
    - not add any salt or chlorine yet
    So at what time do we add the salt, CYA, or do we need to do bleach for a while until the plaster is fully cured ?
    When should I start managing alkalinity/hardness ?
    What's a good source for pool salt ?
    And after how many days is it safe to use the pool and walk on the plaster ?
    Thanks a lot !
    Patrick
    Completed July 2008: 25,000 gal IG gunite, 3M "Smoke" Quartz, 6' sheer descent w/ fiberoptic light bar, 2 Hayward ColorLogic LED lights, IntelliFlo VF (running at 160 watts to filter - yeah !), Jandy PDA PS8, Jandy Aquapure 1400 SWCG (running at 15% :o) ), 8 "Jet Flow" returns, 450 sq ft Hayward cartridge filter, 480 sq ft HelioCol solar panels, Hayward VacAlert, Hayward Phantom Turbo, BBB method, TF-100 Test kit (of course !)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New pool - startup next week - questions
    You will need to add chlorine immediately and maintain it until the SWCG comes on line. Bleach is a good way to go.
    Pool salt is nothing special. Get the Morton's Solar Salt in a blue bag. It will say 99.something % pure. No additives.
    Your pool builder or the plasterer should have very specific advice on water chemistry for the plaster. Pay close attention because you risk your warranty if you don't follow their instructions.
    ktdave's Avatar
    Katy, TX
    888
    JohnT is right on the money!
    You can anticipate fighting pH creeping upwards for at least the first month due to the plaster curing. I went through about 5 gallons of muratic acid during that time, then it leveled off somewhat. So you are right to keep a close eye on that.
    I added CYA immediately and salt after 30 days. My plaster finish IS different from yours (PebbleTec) so do like John says and do whatever your 3M finish warranty suggests (ask builder).
    Good Luck down the Home Stretch!
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Feb 2008
    Princeton, NJ
    46
    Things have gone well:
    FC 2.5
    CC 0.0
    TC 2.5
    CYA 30ish
    CH 200 (I might increase a little bit, maybe to 250)
    TA 80
    PH 7.4 (and creeping upward ever so slowly, plaster/quartz is 2 weeks old now)
    Water is 88deg or so - using solar heat occasionally. Crystal clear ! (knock on wood)
    PB says I need to wait 4 weeks to add salt (640 lbs of Morton's blue bags got delivered today), so I'll wait until I turn on the SWG. It may be overly cautious, but I don't mind using bleach for now.
    Thanks all !
    Patrick
    ktdave's Avatar
    Katy, TX
    888
    That's good hear. Your numbers look good so far, just keep testing regularly and you should have no problems.
    I would wait on adding any CH as it will likely increase as it leaches out of the curing plaster. 200 is good for now, just keep an eye on it every couple weeks or monthly.
    Pool School
    TF Test Kits
    30,432
    Patrick, the "knock on wood" has nothing to do with your clear pool. It's your foresight to have a plan in place for your startup and to have the proper tools (test kit) and chemistry on hand to stay on top of your pool chemistry.
    You will enjoy your pool and maintenance will be easy for you because you made your own "luck". Nice work!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Patrick
    Nice work on your pool chemistry! As duraleigh (dave) said, you have the knowledge and tools to keep your water beautiful!
    Congratulations and welcome to the forum!
    Now, when can we expect to see some pix? 8)
    You're done SLAMing when:
    Feb 2008
    Princeton, NJ
    46
    Thank you for the kind words ...
    I'd be happy to post some pictures when I complete the travertine paver decking (still a big mess) ... but here are some pictures from the build progress.
    http://ths.gardenweb.com/forums/load/po ... 639.html?9
    I'll keep you posted (pun intended)
    Feb 2008
    Princeton, NJ
    46
    I added 560 lb of salt on Friday, and the water has a definitive salty taste to is now. At first I was shocked to see the reading at 5700 ppm, but then I realized that the salt water is heavier, and as it flowed towards the main drain the cell would see a higher concentration of salt initially. Over the next 24 hours it went down and salted at 3200 ppm. The salt test strips from the TFT kit agreed.
    The water somehow feels more pleasant, although the salty taste is an "acquired taste" ...
    Now if I set my solar cells to max all day in the current heat wave I can boil enough pasta in my pool to feed a small country !
