Thread: TF100 Test Kit
    TF100 Test Kit
    I think I read that the chemicals used in the TF 100 testing kits use Taylor reagents. Is this correct?
    Thanks
    27100 gallon in ground Pool/Spa, SWG, Pebble Sheen-Aqua Blue, (All Pentair Equipment) Pentair VS Pump, Cartridge- filter, build completed Dec. 2013, Houston, Texas
    30,421
    Re: TF100 Test Kit
    Yes....repackaged to give you more of the chemistry you use most often.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: TF100 Test Kit
    Yes, that's correct. The main difference is that they are packaged in different sizes based on the tests that many pool owners perform most often. The other notable feature of the TF100 is that it includes the FAS/DPD chlorine test which uses a liquid reagent and a powder. It measures chlorine very precisely up to 50ppm+. It is not stocked by most pool stores. This test is particularly indispensable to a pool owner, especially when correcting pool water problems.
