Results 1 to 10 of 10
Thread: Tyrone Shuz
    Tyrone Shuz
    Hello all!
    Now I'm a grizzled veteran pool owner (7th season) and found this place after the disappearance of the mythical deity known as "Ben".
    I don't need much help these days, but still do occasionally.
    16' x 32' IG vinyl DE ~18,000 gal hole in my back yard.
    I play music, and you can hear some here
    Mar 2007
    Morris, IL
    477
    Welcome to the site. Even Grizzled Veterans can come here, without them there would be no help to be had.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Arizona
    924
    Hey there! I'm tapping my foot to one of your tunes right now. (the one for Dominic) Sounds great!
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Even though you have it down pat, others here may benefit from your years of grizzly experiences!!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Buggs, glad you're diggin' the music!
    As far as "down pat", well I /did/ have it down pat, but I no longer do! I was using pucks/sticks, but I'm out, and I think I want to go with bleach, and I will be asking about how much to use daily, etc. You'll see me in the PLEASE HELP section!
    Arizona
    924
    Full set of test readings, pool volume and pool type - front and center! LOL!
    Buggs
    Enid, Oklahoma
    53
    Hey, have I seen you on the FDP?
    20K IG Fiberglass, 3/4 hp Sand, Hayward ColorLogic
    Jun 2007
    Panama City, FL
    5
    Can't be more than one Tyrone Shuz. You the same guy from the FDP?
    Yes, it is I! But you gize must have different handles over there (except maybe Nocaster!)
    Enid, Oklahoma
    53
    I've only lurked over there. I use nocaster on forums because Fender guys pick up on it...not because I own one our would ever be able to.
