Results 1 to 7 of 7
Thread: Check Valve Surprise
    Jan 2014
    SE Louisiana
    147
    I just recd my jandy chk valves from UPS. Was so happy to see everything I need to finish my plumbing tomorrow. First thing I read on the instruction manual is "This check valve is not designed for use with air blowers".
    That's exactly what I just purchased them for. I have two stub outs at my spa. One for lower leg jets and one for back jets. I got advice to plumb check valves as close to the spa as possible to prevent water backup in the air line. Explanation was that you wanted as little water up the line as possible so the blower didn't have to work OT to push it out. I have plans to put a hartford loop just a few feet away from spa, but was told that chk valves would still be worth it.
    I decided to get the "better" chk valves ... but now i see this "don't user for air blower comment.
    If I can't use these really good check valves, then what can i use!?
    38,507
    Re: Check Valve Surprise
    Shouldn't the blower be strong enough to clear out the lines without check valves? I have not heard of needed a check valve. Actually if the spa is properly designed, there is no need for a blower at all usually.
    Oct 2007
    Valrico, FL
    542
    My "therapy jets" don't use a blower at all.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Jan 2014
    SE Louisiana
    147
    This is my first time plumbing, so I really don't know how is going to work out. On one side of this, I hear comments like yours regarding people not needing blowers at all. On the other end, I hear people saying the don't get any good air flow and they burn up blower motors. I do plan on putting the loop in, so the blower would only need to clear about 6 feet plus the amount of air line in the spa if I don't put the check valve in. I guess I was figuring that the check valves wouldn't hurt.
    Jan 2014
    SE Louisiana
    147
    Btw ... I did more research over the weekend and the blower motor I plan to get calls for a 1/2 lbs air valve. Soooo ... lesson learned for me. 1 - air and water check valves may seem to look and be identical, but they are considered different. 2 - you need to get the right kind of lbs rating for the kind of blower you buy.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,057
    Seems to me the simplest thing to do would be to mount the blower above the water level. Then you don't need any check valves. That's how mine is.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Most blower motor mfgs sell a simple inline check valve. They are clear plastic and have a spring to allow pressure out.
    They also help moisture from coming back up into the line and into the motor housing and brushes - that can rust and fail prematurely.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
