Thread: Cleaning sand dollar filter
    May 2013
    Arizona
    112
    This is second season with this system and was told should use a cleaning solution especially since we do t close pool. There is alot of oily substance that is clearing up. I do not yet have a thru the wall skimmer so how do I add the cleaner to the sand? I've never taken the filter apart can it the cleaner be put in the water or must it go directly in the sand? If so how do I get to the sand? Thanks
    Re: Cleaning sand dollar filter
    The cleaning solution is not normally worth using. It is designed to be used in one specific situation, lots of oil in the filter, which is really quite rare. Oil usually accumulates in the skimmer(s) and never makes it into the filter.
    May 2013
    Arizona
    112
    Quote Originally Posted by JasonLion View Post
    I don't yet have my Hayward thru wall skimmer installed yet, ok so ill return the sand cleaner. Thank you for reply
