Thread: Toying with the idea of building a hottub
    Nov 2010
    South Central Kentucky
    283
    We've been considering the idea of adding a hot tub to the corner of our existing pool or if not a spill over type tub, at least a free standing one. I haven't done much research on the subject yet, but I'm getting started on gathering info. I'm fairly handy when it comes to building/designing things, but I'm looking for info from those of you who might have undertaken a project such as this in the past. What are the positives and negatives? Can I use existing equipment (heater) or would I be better off making it a completely separate system? Should I just construct a place to drop in a tub and not worry with a full DIY project?
    What say ye, oh wise members of this great forum?
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Re: Toying with the idea of building a hottub
    Unless you are both industrious and lucky, buying a separate tub will cost less. It is possible to add a spill over spa to an existing pool but it takes a fair bit of extra effort. To add a spillover means: engineering to insure the weight won't compromise the existing pool wall, trenching (possibly through the deck) to run plumbing lines, either boxing in a fiberglass tub shell or forming a concrete/plaster spa area, plumbing, probably a new automation system (optional but really nice), and so on.
