Results 1 to 12 of 12
Thread: How warm in order to install a new liner?
    Split from another topic. Please ask questions in your own topic, rather than hijacking someone else's existing topic. Thanks JasonLion
    I realize this thread is from last year, but we are looking at doing this for similar reasons to start off this season. How warm does it need to be outside in order to install a new liner? I saw a video which stated 80 degrees, but that would defeat the purpose of us trying to do it at the start of the pool season. Does it really need to be 80 degrees, or can you do it on a day in the high 60s/low 70s if you have plenty of sun?
    12Kgal, AG, Sand, Hayward Swim Pro SW256T PAKS
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Above Ground liner replacement
    I think it was in the upper 60s when mine was installed.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Mine was in the low 70's with full sun. No problems. If you can do it on a nice sunny day I think that makes a difference.
    Jeff
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: How warm in order to install a new liner?
    Okay, I looked up the weather history. The day they installed my liner the max temp was 72 and the min temp was 37. They did the whole job in the morning, so it must have been around 45 when they started and the lower 60s when they finished. It was sunny with very little wind.
    Liners are much easier to install when it is 70+ degrees and full sun, that doesn't mean they can't be installed when it is colder. If this is your first time installing a liner, it is probably well worth waiting for a warm sunny day.
    30,432
    +1 to the above. I have done 2 DIY liner installs........both days 75+ and full sun.
    I could tell it would have been a LOT more hassle if it had been cooler. Perhaps even more important is the full sun.
    Jun 2013
    Erie pa
    68
    Put the liner in your car or truck and crank the heat before install, it makes it a little easier if its cool out and you have no sun to warm it.
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    Also, understand that the liner is sometimes sized based on the expected temperatures. A "winter" cut will be slightly larger than a summer cut. If you try to put in a winter cut in very hot weather, it might be too big. Make sure that whoever you're buying the liner from knows the expected temperature range for your install.
    Support the site
    Jul 2013
    Long Island, NY
    536
    I'm having my 15 foot above ground pool installed by a company on April 10th here in Long Island, NY. After reading this thread I'm wondering if I should push it back. Looking back at weather data for my area average high and lows for April 10 are about 55 high and 38 low. This could be a dumb question, but why would the temperature make a difference when installing the liner.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by richierich View Post
    It will stretch much more if the sun has been on it and the ambient temp is higher.
    I lucked out when my new liner was installed 1.5 years ago. It was in October and just
    happened to be the last sunny 75 degree day. It was a tight fit but they got it in though
    it did stretch the tile pattern a bit in the shallow end.
    Dolphin E10 Cleaning Robot.
    Jul 2013
    Long Island, NY
    536
    does that mean if its done in 50 degree weather the liner won't lay right in the above ground pool?
    SWG: Intex CS8110
    Kneichko's Avatar
    Sep 2016
    Long Island, New York
    33
    I just had a liner installed yesterday. My concern is filling it when the temps in the 50's. will it stretch properly if the temps are lower or is there a better chance of damage because it's chilly
    15'x30'x54" semi inground sharkline extruder 5000, 12,000ish gallons, Hayward EC65A DE filter, auto pilot digital nano+ PPM2/PPC2 manifold SWCG, Aquacal T115 heat pump, 1.5hp pump, hard plumbing, k-2006 test kit
