Results 1 to 14 of 14
Thread: What temperature do you run your heater?
    Jun 2013
    Southeast
    78
    Last year was the first time I ran my pool. I ran it at 84 degrees. Obviously, comfort has a cost. What is a reasonable temperature for keeping it heated for you?
    What is the minimum ambient temperature do you realistically have your heater turned on? Last fall I ran it when it was 60 degrees and I ran it at 84 degrees. Very costly. Hahahaha. What's a. More reasonable temperature outside to run the heater? 70+? 75+?
    24x32 feet, In-ground, Saltwater, Gunite pool (under construction)
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: What temperature do you run your heater?
    I find that my pool water settles at a temperature that is somewhere between the low and high air temperature. I run the heater in the pool once the water temps are around 65F and the high/low air temps would facilitate the water either getting warmer or at least stabilizing at that level. A water temperature of 65F is right at the minimum temperature that I get in the pool, although I would prefer it to be warmer. So when the water hits 65F combined with air temps that will at least support that water temperature on its own, I can justify running the heater to get water temps at least into the 70's. In the spring, Mother Nature is working with you. In the fall, the opposite is true.
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Quote Originally Posted by BoDarville View Post
    That's nuts. I'd turn the heater on if I knew good weather was coming in the forecast just to bump up the temp. Maybe 70-75 ish
    I keep telling myself I will get in with temps in the 70s. I always end up waiting until 80s.
    My biggest problem is going under water (when it's cold) to get my weights situated to hold the steps down.
    I set my heater to keep the water around 80-82 overnight depending on the forecast. Most often I target when I want to swim as opposed to maintaining the temperature.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    The kids will get in at just about any temperature, but we (the adults) generally want the water at 83 or higher before we will get in.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    83 is my lucky number.
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Grandkids don't care what the water temperature is, but with my arthritis, I like it at least 82-83. Warmer is better! We only run the heater if I know for sure I want to get in or we are having a family party.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Jul 2011
    Las Vegas, Nevada
    139
    We heated the pool to 100 for St Patty's Day, and then to 95 last week. Normally we don't heat the pool, just the spa, but we do like to heat it if the weather is nice out of season.
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I like 83 as well.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I prefer 85 degrees. My wife prefers 88 or warmer.
    Thanks!
    David
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have solar heat, so it is more of a goal than a set point in the spring and fall, and I generally set it to 84 degrees, mostly swim in the afternoon and evenings, so it is often close to the goal temperature most of the season.
    Ike
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,059
    We use mainly solar and it was 92 deg this weekend. Normally I keep it at 89-90 in the summer. It is so nice especially if you swim at night.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jun 2013
    Southeast
    78
    It is finally getting to a sustainable 65-70 degrees here in Virginia. I think it's time to use the heater.
    Jun 2012
    western NY
    1,560
    We usually prefer around 85. I have the temp dial stop set on the pool just above that so when I turn the heater on I can just turn it to that setting and forget it. That usually works pretty well. I say usually, as the set screw is not as tight as it used to be and a couple times the dial has gone past that without me really paying attention to it. A couple times I came back to find the pool in the high 90's
