Just did a no drain acid wash.. What should I attack first?
What was the TA before adding the acid? A 200 ppm TA does not make sense if you added a lot of acid. How much acid did you use and what strength was it?
What color did the water change to when you added the TA reagent?
pH nor CYA has no affect on the color of your water.
It is difficult to follow your actions above......why did you shock the pool last night? Isn't your water clear?
neither pH nor CYA has any affect on the color of your water.
Looks like you did another acid wash last summer.....what's up with that?
