Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Just did a no drain acid wash.. What should I attack first?
    Jul 2013
    East Texas
    51
    Ph or TA?
    Ph-below 6.8
    TA - over 200
    Pool looks awesome!!!
    25,000g In Ground Saltwater pool-plaster--rock water fall with water Jets- Polaris 280 vacum-Hayward ecostar pump- Hayward booster pump-TF-100 Test Kit
    38,428
    Re: Just did a no drain acid wash.. What should I attack first?
    You can not really do one without the other. You need to raise that pH back up into the 7s with borax or soda ash. Only way to lower the TA (if you want to worry about it which is not necessary if you just keep the pH in range) is by following this: Lower Total Alkalinity
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Just aerating the pool should drive the pH up. Full blast on that waterfall. Although I suppose I'd raise pH to at least 7 before I started running water through the heater.
    Jul 2013
    East Texas
    51
    The only heat I have is the 80' temp today!! Lol
    I guess I will crank up the water fall..
    Thanks!!
    Richard320's Avatar
    Jan 2010
    19,046
    Quote Originally Posted by Traylork View Post
    Thanks!!
    Whether or not the heater is on, if acidic water is flowing through the copper heat exchanger, you might end up with green haired kids and an expensive leak repair.
    How did your TA get over 200?
    Note: The poster does not list a heater in their signature.
    Support the site
    Jul 2013
    East Texas
    51
    No heater....
    I guess from all of the acid I used to acid wash it????
    38,428
    But acid lowers the TA ....
    Jul 2013
    East Texas
    51
    I will retest my TA tomorrow. It was my first time to use my TF-100 test kit...
    Can anyone think why my TA would be that high ?
    38,428
    Did you wipe the tip with a damp cloth for each drop? Did your drops look full or smaller than others?
    What was the TA before adding the acid? A 200 ppm TA does not make sense if you added a lot of acid. How much acid did you use and what strength was it?
    What color did the water change to when you added the TA reagent?
    Support the site
    Jul 2013
    East Texas
    51
    Got home from work and the pool has turned green!!!
    About to go re-test my TA
    TA regent? Red?
    38,428
    If the TA test immediately turns red, that means your TA is near zero.
    Jul 2013
    East Texas
    51
    Ch-375
    FC-6
    Cc-0
    Ph-7.2
    TA-140
    Cya-0
    Richard320's Avatar
    Jan 2010
    19,046
    Get some CYA in there and go swimming
    Jul 2013
    East Texas
    51
    When I first tested it the Ph was above 8.2... Would that have turned the pool green? I shocked the pool last night and it cleated it up.
    Or could be cause I had no Cya in the pool?
    30,431
    pH nor CYA has no affect on the color of your water.
    It is difficult to follow your actions above......why did you shock the pool last night? Isn't your water clear?
    neither pH nor CYA has any affect on the color of your water.
    Looks like you did another acid wash last summer.....what's up with that?
    Jul 2013
    East Texas
    51
    I keep on getting scale and some red clay stains in the pool... Pain in the rear end!!
    I don't know how to stop them..
    I shocked the pool because it was green when I got home from work??
    38,428
    We don't "shock" around here. We follow the SLAM process ... see Pool School.
  20. Back To Top    #20
    Jul 2013
    East Texas
    51
    I slammed it last night.... Better?
