Thread: New-to-me PF 50 Sand Filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    New pool owner, see sig. Came with old PF 50 sand filter. Only know it's a PF 50 by the appearance and size. Label is illegible.
    https://www.dropbox.com/s/mxfixi0w5n...313_174624.jpg
    Wondering before/during opening if I should do anything special with the sand filter.
    Should I open it up and look at the sand?
    Hose flush if it looks nasty?
    Replace sand either way?
    No clue how long it's been since sand replacement. I do see a bit of sand on the equipment pad, but perhaps that's just from being winterized last fall.
    Once it is running, is it OK to add small amounts of DE to a sand filter this old using http://www.troublefreepool.com/conte...-a-sand-filter ?
    Isolated Spa - 345 Gallons
    38,524
    Re: New-to-me PF 50 Sand Filter
    Open it up and take a look ... and flush out the sand too would not hurt.
    Rarely is there ever a need to replace the sand.
    Sure it is fine to add a little DE ... are you sure you need it?
    May 2011
    Long Grove, IL
    117
    JV,
    I know that you didn't ask for it, but I have attached a scan of the manual. It took me a long time to find a copy for my PF-100 since it doesn't seem to be available via Google and it took a few calls to Pentair before I got in touch with someone who knew what I was looking for, and more importantly, had access to it.
    https://www.dropbox.com/s/xmkem0ymlh...ilter%20OM.pdf
    Also, I completely rebuilt mine last year so if you have any questions about how things should go together I should be able to help.
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    Feb 2014
    Central Minnesota
    5,080
    I had been scouring the web for a month. Guess I should have given them a call.
    Thanks so VERY much for hooking me up with a manual!
    Jay,
    Thank you for attaching the PF50 manual to dropbox. I just grabbed it.
    I busted the pvc pipe that comes out of the bottom of the PF50.
    So I got a replacement and have installed it. Now I am having a water leak at the bottom.
    Since you completely rebuilt yours in 2010 would you mind communicating with me about my problem?
    Thanks
    Jim
    Quote Originally Posted by griffths View Post
    JV,
    Regards,
    Jay
    Beachcomber 580, 430 US gal.
    May 2011
    Long Grove, IL
    117
    Jim,
    What sort of assistance can I provide? I have a PF-100 which is constructed a little different but am happy to help any way I can.
    Jay
    Jay
