Thread: Pool opening timing and temps questions
    Jun 2010
    Central Indiana
    92
    So our winter cover has blown off and torn and we are starting to get some warm temp days out so I was thinking about getting the pool the rest of the way filled up and opening it for the year. But I am not sure if we can because of the temp swings. For example the highs are in the 70s the next couple of days then next week we are going to have 3 days with the highs in the 40-50s with lows in around 28-30. Will this damage my equipment/pool being out in that temp? What should I do? I dont want algae with raising temps and no cover but dont want my pool/equipment damaged either
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Re: Pool opening timing and temps questions
    Your low temps probably won't last long enough to freeze anything if the temps are headed back up. Even if they do, just run the pump while it is freezing--you probably need to circulate anyhow! Get that pool in gear!
    Feb 2012
    Maryland
    400
    What are your current water temps?
    Agree with woody, while lows might dip below freezing at night, I doubt it would be long enough to cause even a skim of ice if your water temps are well above freezing.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Jun 2010
    Central Indiana
    92
    Temp today is 55. Today is the first day it is supposed to be in the 60s-70s
    Feb 2012
    Maryland
    400
    Quote Originally Posted by newguyjosh View Post
    At 55, definitely get it open before the green monster strikes
    Jun 2010
    Central Indiana
    92
    Well its gonna take me a couple of days to get the water level high enough to run the pump. I was thinking about putting a floater with tabs in there (have some in shed from previous owner) in the mean time as the CYA was essentially non-existent when tested.
