Thread: tried to clean my sand yesterday for the first time
    Apr 2014
    Louisiana
    51
    Not backwash/rinse
    My pool had become pretty stagnant, I had some blockage at the impeller and the pooll is full of particles. I decided that i would open up the filter and try to clean some of the sand which i'm pretty sure has never been done before.
    I am pretty sure this is the exact model i have
    http://www.aquapoolstore.com/filters...-operation.htm
    It didn't quite go as i expected:
    - I unscrewed the top spinner and heard the pressure rushing out
    - i removed the cap and two pieces inside
    - what i saw was a drain pipe and water which looked pretty dirty
    - so i put the hose in on a low setting and starting running water
    - I was unsure about what i should set the filter to. I left it on 'filter'
    - it took a really long time for water to come over the top as some was going down the drain
    - eventually, i found it more useful to put a couple inches above the drain pipe, stick my hand in and stir up debris then switch the pump to 'drain' and remove the hose. This would cause trash to go down the drain.
    - I felt like i got nowhere near having 'clean' water and the sun was going down.
    Can someone offer more adivce on how to do this?
    i was thinking about putting water in and using my wet vac to suck the water out, the whole draining process takes a long time and just trying to let the trash overflow out of the top was taking even longer.
    Does it sound like i have unusually dirty sand?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    30,419
    Re: tried to clean my sand yesterday for the first time
    1. This is not pertinent to cleaning your sand but there should be no pressure....sounds like you have a suction side air leak
    2. There will be little water moving through your multiport, but I would set it on "waste"....no big deal either way
    3. find a way to plug the drain. Personally, I don't overflow. I just scoop out the solids with a small aquarium net.
    4. What are your settings other than drain?
    5. You are not trying to get the water "clean", you are trying to remove solids from your filter and make sure the sand bed has no clumps.
    Apr 2014
    Louisiana
    51
    1. not pertinent to cleaning your sand but there should be no pressure....sounds like you have a suction side air leak
    How bad is this? is that something i need to try and remedy right away?
    Sorry, i dont know why i worded it like that. I meant 'waste'. i have filter, waste, rinse, backwash and (not sure about this one but 'close' maybe)
    how big are the solids i should be conderned about? i mean there were little bits of this and that floating in there but nothing bigger than like grass stalks. I didnt have anyhting like the size of marble for instance. The sand didnt seem clumped at all.
    So i'm getting the idea that this may not be necessary. No?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    30,419
    Treat your suction side leak later.....let's get your filter cleaned.
    Thanks...."waste" is what I was looking for.....not "drain"
    Not at all but, remember, this is an inspection as well as a potential cleaning. Every two years, I perform this procedure. One time it was pretty messy and I had a lot to scoop out.....other times it was almost colean enough to leave alone.
    Get out the big debris....the filter will catch the "dirt" and eventually backwash it. Sounds like yours is clean enough!
    Apr 2014
    Louisiana
    51
    thanks, this site is awesome. I was about to hire a guy for 120 an hour to look at my problems but this site helped me fix for free and only about an hour of work so far. the next step is getting my water chem straight.
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    38,284
    I will just leave this here for your consideration
    Become a TFP Supporter
