Results 1 to 9 of 9
Thread: tiny, tiny bubbles?
    Feb 2012
    Maryland
    400
    tiny, tiny bubbles?
    I know I have a small leak on the pump side of the filter connection. When I say small, I mean a drip every 2 minutes or so. I noticed on my returns I have some very, very small bubbles when the pump is on low, when it is on high the bubbles are gone.
    Is this due to the tiny leak or maybe when its on low something else is going on?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    30,432
    Re: tiny, tiny bubbles?
    A water leak on the pressure side will not allow any air into the system until the pump is off.
    If your bubbles appear continuously while the pump is running, you have a suction side leak.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It is from your SWCG. Perfectly normal.
    A leak on the pressure side of the pump won't introduce air into the flow.
    38,537
    You have a SWG, they produce bubbles. Although usually more visible on high speed.
    Check if you still have bubbles when SWG is not generating.
    Feb 2012
    Maryland
    400
    Ok, this makes sense then. My SWCG only runs during low speed, because my pump is cycled to start low and then late in the day it kicks high for an hour, by the time it kicks high the percentage is met and SWCG is done.
    Thanks!
    30,432
    I missed the SWG in your equip.....sorry.
    38,537
    That is not how the SWG works. The percent setting is over a shorter period of time like an hour or so. It will turn on and off multiple times through the day.
    Feb 2012
    Maryland
    400
    Yep, agreed, However, it is always off (percentage met) earlier in the day. So it isnt adjusting the percentage over a long all day period, it just seems to get it done.
    38,537
    Well, I would still suggest turning the SWG off and seeing if you are still getting bubbles. And see if you get more bubbles when the pump is on high and the SWG in on.
