Thread: First time adding salt
    Oct 2013
    Baton Rouge, LA
    86
    Hi guys, I just receive my circupool si45. I just picked up the 800+ lbs of salt from home depot and am curious the best way to add to the pool? I have a 32000 gallon vinyl pool with a sand filter. Thanks
    30,000 gallon In-Ground vinyl, small fountain, Polaris 9300 robotic cleaner
    38,235
    Re: First time adding salt
    Dump it in. And if you have kids, let them play with it.
    You should test the salt level before you add because you may not need all that.
    Hopefully you got solar salt to save yourself some money.
    Also circulate at least a day before turning on the SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    If the water is warm enough.... Diamond Day. Check out post #5
    Oct 2013
    Chapin, SC
    1,141
    Excess salinity will take a long time to get rid of. Make sure you have an accurate test done. Trust me, it wont be at a pool store. Both stores I took samples too were 600 and 1300 ppm lower than what it really was using my 1766 test kit. Strips aren't much better. I wish I'd bought my taylor 1766 tester before I started pouring salt in my pool. Dont trust the salinity levels your si-45 is telling you either. Mine have never been close. Today the instant is 4300 which is as close to the actual 4000 my 1766 test says it is as ever before. But the aversge is still showing 2800. Unfortunately, the cell will stop generating chlorine based on what it thinks the salinity level is right or wrong.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We beat the bags with a hammer to break up the clumps and dump and brush. Make sure you run filter for 24 hours before testing. We always do 80% of recommended salt then test and add more if needed. Usually the recommended amount is a bit high to get the right amount. Enjoy!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
