Thread: Poolvergnuegen Hose and Hose Leader
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    I recently made a steal of a purchase from eBay for The Pool Cleaner 4X for only 50$ Shipped!!!! Anyways it didn't come with hoses. Whilst looking into the matter I have made the discovery and desision that I will simply use my Baracuda hoses if there are no strong objections.
    I have done some reading about the leader hose and an curious as to why this hose is so special. On my hose setup currently I certainly do have a hose that is a female to female that is nessasary in order to hook up the cleaner to the male to male hose lengths!
    Just curious what you guys think..
    26k IG Vinyl, 2 HP single speed,24" Tagelus Sand, 1.5" pipe, 1 Main, 1 Skimmer, 2 jets, pool built 1983, new vinyl 2014, 36'x18', Deep End 8', The PoolCleaner 4X Suction.
    Pool Math #__# Pool School #__# Best Android App "Pool Pal" Track Your Levels!
    Jun 2011
    Long Beach, CA
    2,778
    Re: Poolvergnuegen Hose and Hose Leader
    The leader hose has two floats that you should be able to get and add them to the hose you are using if the cleaner is not running properly. I never adjusted mine as it seems to run just fine with the placement of them from the factory. Try this link to read the manual, http://www.thepoolcleaner.com/PoolCleanerSUCTION.pdf.
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    Awesome, thank you so much ping. I am so anxious to open our pool this season. This will be my first opening. I can't stand seeing that blue tarp that protects our pool from the evil gumball tree above it!
