Results 1 to 8 of 8
Thread: My TA is 130 however my PH is stable at 7.6 to 7.7
    May 2012
    Oconee, Georgia
    82
    I am checking it at work in our lab. On a $5000.00 ph machine. Is this possible or am I getting a bad reading on my TA
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: My TA is 130 however my PH is stable at 7.6 to 7.7
    As long as your PH is stable your TA is in a good spot. The TA doesn't have to be in a certain range as long as your PH is stable.
    Jeff
    I am quite surprised. But maybe there is more to buffering pH that just TA..... maybe someone who knows will jump in with some facts.
    PH increases are very dependent on the amount of aeration. In a simple pool without water features or a SWG the amount of aeration is very low and PH increases due to high TA are minimal, allowing much higher TA levels before you notice anything.
    Or more straight forwardly, if you aren't having a problem, don't worry about lowering your TA.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by JasonLion View Post
    There you have it in layman's term's
    Jeff
    May 2012
    Oconee, Georgia
    82
    I have a SWG but after getting CYA to 80 it only runs 50% of the time on a 5hr cycle. My FC was 4 today
    May 2012
    Oconee, Georgia
    82
    Is it ok to do the Borax thing with that height if a TA.
    Yes, you can do borates now. I would suggest using boric acid.
    Support the site
