Thread: Where is the thread for opening pools with pictures?
    Mar 2013
    Rochester, NY
    86
    Hi
    At one point I was able to bookmark the threads i wanted to save. However, I feel that the site has changed slightly and I'm having a hard time doing that. So I'm looking for the thread from a member that showed (with pictures) all the items they had to open up their inground pool. If you have seen it, could you add the link to this post for me?
    Thank you.
    18' x 38' IG Vinyl 21K
    1.5 Hp Hayward pump
    Double main drain, 4 returns
    Rheem heater
    18' x 6' Sun ledge, Automatic Cover, Interfab Extreme Slide
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: Where is the thread for opening pools with pictures?
    I don't know about pictures, but here is the standard pool opening guide thread...
    http://www.troublefreepool.com/threa...-Pool-Openings
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Mar 2013
    Rochester, NY
    86
    Thank you peterdaly. This one is easy to find. I'm looking for one that a member posted. It was a step by step with pictures. very informative.
    1.5 Hp Hayward pump
    Rheem heater
    Mar 2013
    Rochester, NY
    86
    Ok, I found what i was looking for..... However it's not for opening, it's for closing. Still very helpful with pictures. http://www.troublefreepool.com/threa...r-closing-pool
    1.5 Hp Hayward pump
    Rheem heater
