Thread: Maintain your chemicals correctly
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Received a call from a customer that I installed a gas heater for 5 months ago. He said its leaking water. Not good. Went and investigated and sure enough, really bad. I took the unit apart and found the worst chemical damage ever and the unit was only 5 months old. Here are two pictures. One of a shinny new copper heat exchanger and the other one is the one I pulled out. Notice that there is NO copper showing at all. It's all been eaten away thus leaking. 5 months old!!
    Maintain your chemicals correctly and if you have a pool guy like this guy did, make sure they are doing their job.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Maintain your chemicals correctly
    Wow.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    38,262
    That is amazing. Was anything obvious about what would have caused this to happen so fast? Like a tablet feed just before the heater?
    It seems mind-boggling to me that the pH could have been kept low enough for this to happen that fast.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    The PH was WAAAAYYY off and for the entire 5 moths. When I checked it the day I went it was 5.0. Chlorine was zero as well.
    Today when I replaced the heat exchanger the PH was 7.2, still .82 on the chlorine and ALK was 94.
    Paul
