Thread: TA readings with high FC?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I know pH readings are skewed when FC is above 10. Are TA readings also affected?
    Example:
    3/27/14
    FC: 15.5
    CC: 0.5
    pH: 8.4
    TA: 120
    4/8/14
    FC: 5
    CC: 0
    pH: 6.9
    TA: < 30 (turned at 2 drops, slightly pinker at 3)
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Re: TA readings with high FC?
    The TA test is fine at high FC levels. The colors it turns will sometimes be a little different, but the results are still valid.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    In that case I am very puzzled. I did the test twice on 3/27. I was properly wiping the tip on a dampened towel between each drop. It was 12 drops each time. The 13th drop didn't change the color. 11 days later I've somehow lost 75% TA!?
    Quote Originally Posted by JasonLion View Post
    Your PH has also come down dramatically. Presumably you added acid to bring down the PH, which will have also lowered the TA level.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I didn't add any acid. I assumed the high pH was only due to the high FC. Still wondering what happened.
