Thread: Got algae - Am I on the right track?
    Bryan's Avatar
    May 2008
    Tarpon Springs, FL
    29
    Swam in the pool last Sunday (6/22) and the water looked great. Then it rained a couple of days last week and I wasn't home one single night to clean/brush/etc. Pulled the solar blanket off Saturday morning and whammo: nice green murky water. And wouldn't you know it, I was leaving town at noon (only for a day, thankfully). So I dumped the last little jub of bleach that I had into the pool and left the pump running. When I got back in town Sunday (6/29) I took a sample to the pool store (no, I don't have a TFP test kit - yet). #'s:
    FC = 2.5
    TC = 2.5
    pH = 7.9
    TA = 130
    CYA = ~20
    When I got home, I put in 2 lbs of dry acid and 2 lbs of stabilizer, then 2.72 gallons of bleach. An hour later I added another 1.36 gallons of bleach, since my test kit only goes to 5ppm and I couldn't tell if I had lost any chlorine. Before bed I added another 1.36 gallons, and when I got up this morning I checked the FC and it was somewhere above 5. I added another jug and went to work. Oh yeah, I also brushed on Sunday. When I got home tonight (Monday), I brushed again and added another jug (1.36G). Oh, and the FC was around 5.
    So, am I doing the right thing, or am I using too much bleach? The water doesn't seem to look any better. Is it too early to see a difference? Thanks for all the expert advice!
    Freeform marcite IG, approx 8000 gal, 1 hp pump, Hayward cartridge filter, BBB method
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Got algae - Am I on the right track?
    It can take a while to see improvement. Dilute your pool water sample with 3 parts distilled water, and then multiply your chlorine reading by 4 to get your actual chlorine concentration. Shoot for 15ppm, and hold it there as much as possible. Check out http://www.troublefreepool.com/turni...sis-t4147.html for more details.
    Bryan's Avatar
    May 2008
    Tarpon Springs, FL
    29
    John, thanks for the tip on the chlorine reading. I'm starting to see why a good test kit is invaluable
    Bryan's Avatar
    May 2008
    Tarpon Springs, FL
    29
    Thought I'd post a follow-up on my algae outbreak. I stopped by the local Aldi store after work, where the fellow behind me in line figured I must be cleaning a lot of toilets with my 24 jugs of bleach Checked the FC, but totally forgot John's tip, and guessed it to be about 5ppm, so in went 3 jugs. This was at 7pm. Just checked it (11:30pm) using John's tip this time, and it measures somewhere around the 12-16ppm mark. The water is looking much better tonight, kinda reminds me of the Caribbean So hopefully it'll be all ready by the 4th, and at a fraction of what I would have spent the pool store way! Thank you TFP & BBB!!!
    Jun 2008
    Marana, AZ
    347
    Probably took less time and less work than the pool store way, too! Glad it's looking better!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
