Results 1 to 12 of 12
Thread: pressure gauge
    May 2013
    East Tennessee
    57
    pressure gauge
    oops left my hayward pressure guage connected to the filter top all winter.
    it shows 40 psi with no water hooked up yet gezzzzz
    time for a new one ?
    24' 13,500 gal round AG 06/01/2012
    hayward 1.5 dream line sand filter
    TF 100 !
    38,248
    Re: pressure gauge
    Yup. Check out the liquid filled ones at tftestkits.net ... I just got one and it is much easier to read.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: pressure gauge
    Yep.
    Check at a farm store. You can often find bigger gauges that are higher quality and cost less. Just make sure it is a 0-60PSI gauge.
    38,248
    Re: pressure gauge
    Quote Originally Posted by JohnT View Post
    I don't think I agree with this 100% ... my pressure never gets over 20psi, so I prefer the 0-30 gauge I just got. I would think that most pools do not go over 30psi, although there are some with large pumps and in-floor systems that do and would require a 0-60 gauge.
    SW Indiana
    9,198
    Re: pressure gauge
    I've never seen a 0-30 gauge in a farm store though. Most are 0-120. 0-60 works fine since 18-20psi is about a third of the scale.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: pressure gauge
    Do I need a liquid filled gauge or do they just perform that much better? I have a 0-30 non-filled gauge I was planning on using.
    Isolated Spa - 345 Gallons
    38,248
    Re: pressure gauge
    supposedly the liquid filled last longer and maybe more consistent(?)
    30,403
    Re: pressure gauge
    I got a 0-30 liquid gauge and liked it enough to start carrying them at TFTestkits.
    They are 2.5" in dia. so quite a bit bigger than standard on a pool filter and the gradations are much wider and easier to read.
    There big advantage is they will not freeze down to around -20 F. That's more than I'll ever see so I am able to leave my gauge attached all winter.
    At 10-11 dollars, they are not a steal UNLESS you were ordering chemistry anyway......that makes the shipping essentially free.
    So, do you need one? Absolutely not but they are obviously nicer than the air-filled and noticeably easier to read.
    May 2013
    East Tennessee
    57
    Re: pressure gauge
    thanks for the repies just got a $7 dollar replacement at pool store
    and thanks to every one here i converted fm baqua last spring when i opened to a murky pool
    opened friday to cristal clear water tests were perfict !!!!
    TF 100 !
    Sep 2014
    San Ramon, California
    65
    Re: pressure gauge
    Dave - is the one on TFTestkits.com made of stainless steel? And is it made in the USA?
    14,000 gals; IG gunite - Wet Edge Primera Stone finish; Sta-Rite/Pentair Intelliflo variable speed; Sta-Rite/Pentair system3 S7M400 cartrige; Sta-Rite Max-E-Therm 400 heater; (Pentair Rainbow 320 Chlorinator- for vacation use only); built-in automatic pool cover; Trident II UV system (on recall not currently used); built 10/31/2012; TFT-100; MX8 cleaner
    Aug 2014
    Shallotte, NC
    693
    Re: pressure gauge
    Mine didn't make it through the winter, either. This is what I replaced it with.... an oil filled gage of appropriate capacity and a method to remove it from the system when not in use and/or drain it.....
    Oct 2014
    San Antonio, TX
    449
    Re: pressure gauge
    I just received the one from TFTestkits.net and it is stainless steel. Feels far superior to my original Pentair that was plastic, only lasted 8 months, and cost $27 to replace from Amazon. And it is really easy to read from a distance. Love it
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
