Thread: Putting CYA in dolphin floater?
    Hi
    I am really fighting with getting CYA to dissolve in my 45 degree water. I have tried the sock in skimmer approach but I am only pumping about 4 hours a day and this is going nowhere. Has anyone tried to put the sock in a tablet floater and just let it sit? Any concerns if that floater gets stuck in a corner and the low ph discharge to the vinyl if I tried this approach?
    Thanks !
    16 X 32 wooden frame with aluminum braces in ground pool. 3.6ft shallow end, 8.5ft deep end. 22,000 gallons. Pool constructed in 1976 in Chicago area. Mechanics: 1HP hayward super pump, Jaccuzi sand filter, Hayward SWG, and Raypak 2100 heater. No main drain (capped years ago) 3 jets, 1 skimmer. Liner replaced May 2013.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Putting CYA in dolphin floater?
    Try putting it in a sock and hang it in front of a return with pump running till it's dissolved. If you do put it in the skimmer again make sure to let your pump run till it's all dissolved.
    I know it dissolves slower with the colder water temp.
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    The 4 hours a day is your problem. You should let the pump run for a solid 24 hours even "after" it is dissolved.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Don't do the tablet floater. It will take forever to dissolve that way. And I would be concerned about damage to the liner if it settled in a corner. The way I did it was to put it in a sock in the skimmer and let the pump run 24 hrs per day. Every so often I would squeeze the sock. Even so it took a couple of days for 7 lbs of CYA to dissolve. I tried in front of a return, but it seemed that some was settling to the bottom of the pool, so the skimmer worked better for me.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Thank you. I will just have to be patient
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes. POP. Pool owner patience !
    Jeff
