Results 1 to 15 of 15
Thread: Should I replace the sand after clogging the filter?
    Shelley N's Avatar
    Denver, Colorado
    199
    In closing the pool last fall I think I did a really good job of clogging the sand filter. I thought I was going to waste, bypassing filtering, but I must have been incorrect because it stopped moving water after a while and there were a lot of leaves in the pool. We took the multiport off but it was clear. We threw down our toys and went home. Soooo, now comes the time to make some decisions. Do I vaccuum out the old sand and put it back in or replace it?
    Shelley
    Denver, CO
    38,539
    Re: Should I replace the sand after clogging the filter?
    There is hardly ever a need to replace sand. Fire up the pump and do a good backwash. Then open up the filter and inspect the sand and run a garden hose gently through the sand to clean it and let the gunk spill out.
    Shelley N's Avatar
    Denver, Colorado
    199
    I don't think that will work. It was completely plogged with no water movement when we closed in September. I've got to at least inspect what happened.
    Shelley
    Denver, CO
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    What jblizzle suggested should be your first step on your "inspection" list.
    Shelley N's Avatar
    Denver, Colorado
    199
    I'm so sorry everyone, I must be missing something. This is an above ground pool that I totally plogged the filter up with leaves when closing the pool last year. Once I fill the pool up in May with water to "test" the filter, I won't be able to take it apart in case I need to. Is there even a possibility I won't have to remove all the sand to remove all the debris/gunk I filled it with? I figured it would be cement by now.
    Shelley
    Denver, CO
    Vette's Avatar
    Jul 2012
    Ohio
    404
    You don't have valves that you can use to shut off the water supply to the pump equipment? If you have those, you should be able to take apart the filter even with the pool filled.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Can you post some pics of your equipment?
    That would help us to help you better.
    Apr 2010
    East Texas
    9,659
    Are you QUITE sure that it is not a plugged line instead of the filter?
    Shelley N's Avatar
    Denver, Colorado
    199
    I have a sta-rite JSAL210F sand filter. We have a back flow preventer, but it doesn't work 100% to prevent leaking. All the lines are removed and put under the deck for the winter and are clear.
    Shelley
    Denver, CO
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Are you sure that the leaves made it to the filter? Could some of the leaves gotten into the pump and clogged the impeller?
    I'd be thoroughly checking the pump for any problems before removing the sand. If you still think the filter is plugged after checking the pump, you can clean it as jblizzle has suggested.
    One question about your pump: Does it have a basket on the inlet? Has that been cleaned?
    Shelley N's Avatar
    Denver, Colorado
    199
    I removed the basket because I was attempting to just pass the leaves through everything to the backwash hose. Hmmmm, I wounder if it is the pump. We bring it in every year and it's in the basement. Do I need to take something apart to see a problem? It's a 1.5hp dynamo. Ugh.
    Shelley
    Denver, CO
    38,539
    Yeah ... you can't do that. The basket is there for a reason. Likely your impeller is packed with leaves now. You should split the pump apart and clean out the impeller.
    Shelley N's Avatar
    Denver, Colorado
    199
    THANK YOU EVERYONE! The hubby took the pump apart yesterday and the pump was packed with leaves! We would have gone though all the filter rigamarole and come up empty if it hadn't been for you all. Love this place.
    Shelley
    Denver, CO
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Glad you got it sorted!
    May 2013
    mid-TN
    102
    Quote Originally Posted by Shelley N View Post
    hi shelly, do you have a leaf rake?
    I use mine during the fall and spring to clean the leaves up so they do not clog the filter.
    I do this before I vacuume the bottom silt to waste.
    18X36 Grecian 24400 est., pacfab sand Triton II, 1.5hp AOSmith, clormatic 2
