Results 1 to 11 of 11
Thread: AGP Heater Recommendations
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Considering getting a heater down the road for my 30' pool. It is almost 22000 gallons. I was considering the cheap Hayward gas heater( model number H100ID1) but I'm seeing it has gotten terrible reviews. Any recommendations?
    30' by 54 Above Ground Pool 22000 Gallons
    1.5HP 2-Speed Hayward Powerflo Matrix Pump
    24' 300lb Hayward Sand Filter
    TF100 Test Kit
    Youngest Pool Enthusiast(Hopefully)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: AGP Heater Recommendations
    I don't know what the answer is, but just be aware that an AGP will bleed off heat a lot faster than an in ground. A "Big'un" is my best guess!
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Well I'm trying to establish if a heater is worth it for a pool in general. I found some expensive in ground heaters for over a grand. Not sure what size but I'm assuming a 150K BTU is too small.
    TF100 Test Kit
    Nov 2011
    Moberly,MO
    1,010
    I wouldn't recommend anything under 300k and if you are doing that you might as well go 400k. An aboveground isn't impossible to heat just expensive.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    38,521
    Yup, heater size it dependent on the pools volume ... yours is big so you need a big heater to get any kind of quick temperature rise. Also Raypak seems to get much better reviews that the other manufacturers.
    What are you hoping to accomplish with the heater? Just a little added heat in the summer or heating it up in the winter?
    Feb 2013
    Yukon, Oklahoma
    220
    I am probably the only one here stupid enough to keep a heated 14' Intex pool going year round.....and with electric heat at that!! The way it was/is feasible for me was to put 1 inch of the blue foam insulation around the sides and "float" 1 inch of the blue stuff on the top when the pool isn't in use. I made a pvc stand to hold the sections that float when not in use. All that said, it could be done on your pool that way too (mine always has a cover on it), but it would certainly be on a much bigger scale for yours. You would still need to have alot of heater available when uncovered if the outside temp was say 60 degress or so. My pool stays around 90 degrees so it's warm, but not hot tub warm. Enough to keep kids from getting cold and uncomfortable.
    I would say get the biggest heater you can get which is 400K right now. Gas or LP, your choice. Depending on how you use your pool will depend on how bad it will cost to keep using the thing. You will get a feel quickly on how many hours it will take to heat the pool up per degree you want after you use the heater. I tend to put the juice to mine on Friday morning knowing that generally my pool will be used Friday after school, Saturday around noon to around 5pm, then maybe Sunday from around 1pm to 5pm....that's it. Since I am fully insulated, I will let the pool cool until the next week depending on how cold it is.
    Good luck!!
    Bob E.
    Mar 2014
    Kansas City
    7
    I, too, am trying real hard to justify getting a heater for my 9,000 gal AGP in Kansas City. It is sad that it may not be practical. Maybe if I spray foam insulation around the sides. I just want to warm it a few degrees so I can use it in May and Sept.
    Casey's Avatar
    SW PA
    10,457
    Get a solar cover and make sure you use it at night! It'll help keep the heat in.
    Jun 2012
    western NY
    1,562
    Quote Originally Posted by Metallica View Post
    You need a min of 200,000BTU to get a 1 deg temp rise/hr in that size pool. As someone mentioned, a 400,000 BTU would be best. That Hayward will only do about 100,000 BTU/Hr
    Apr 2014
    CT
    25
    We have a "Heat Siphon" heat pump from US Thermoamp. My impression is that gas heaters are great for getting the pool up to temp in a reasonably quick time (and are preferred by weekenders for that reason) while heat pumps are more economical when it comes to maintaining temperature (possibly better for people who use their pools frequently). It's mostly good for starting the pool up earlier in the spring, when the water is cold, but the air is getting warm. In the fall, it's a nice idea, but we've found that the air just tends to feel awfully chilly going into September (we live in Connecticut). Other than that, we started using a solar cover (and a GLI "whirlwind" reel), and found that the heat pump doesn't run much during the summer. (We've had the pool up to 90 degrees from the solar cover and at that point it's *almost* not even refreshing.) So far, we've had it in for 5 seasons (with a SWG) and have only had a minor part failure on it. They're not cheap, though - you'd probably be looking at $3500-4000 for a model big enough for a 30' pool.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    ctgardener, you should pool your pool specs in your signature so everyone can see what sort of pool you own and equipment you use.. Go into your settings and edit your signature
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
