Thread: Replacing jandy lxi temperature sensor?
    Feb 2009
    NW Chicago Suburb, IL
    75
    Any tricks that I need to be aware of? Looks like all I need to do is unscrew the retaining bolt and replace. Is it that simple?
    I'm assuming that the sensor is bad. Heater setting always is at least 5 degrees higher than the actual temp in the pool. I don't remember it being that way last fall.
    I ordered a new part from amazon for $60 and am thinking I can swap out myself. Just want to make sure I'm not missing something.
    Thanks.
    15,000 Gallon IG 15x30 fiberglass
    CoverStar auto safety cover
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
    Feb 2009
    75
    Re: Replacing jandy lxi temperature sensor?
    Anybody? Bueller?
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    That clip that bolts on not only holds the sensor in place, but also seals water from leaking. Make sure that the clip is strait or it wont hold the sensor at the correct angle, and it may seep.
    "My father loves this car more than life itself..."
    "A man with priorities so far out of whack doesn't deserve such a fine automobile."
    Factory Warranty Station for:
    Feb 2009
    75
    Thank you. I'll pay attention to that when I replace it.
    "Life moves pretty fast. If you don't stop and look around once in a while, you could miss it."
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
