Thread: Pump Problems
    Jun 2013
    Atlanta GA
    18
    Pump Problems
    Hello Everyone! I'm in Atlanta GA with a vinyl pool. We were vacuuming, and getting it ready tonight, but it had a fair amount of pollen, tree bits, and leaves in it. (And some sweetgum tree balls) I had my basket in the whole time, as well as the pump basket.
    All of a sudden, the pump got really quiet, and no water was flowing. It wasn't sucking, pressure was 0, no water was moving in the glass before the filter, or before the pump. BUT, I could still hear the motor running. It was like a blade wasn't spinning. I quickly shut it off.
    Attached is a picture of my pump. Can I open that band around the front of it, and see if something is stuck, or is my only option to call a pool repair person. Of course, this was after I poured in bleach to shock the pool.
    Any advice appreciated, this is only my second year with a pool.
    Thanks
    Pam
    30k gal, IG, Vinyl, sand (250, 250 gpm,) 1HP Pump No main drain, Single Skimmer, Older pool
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pump Problems
    How confident are you that the pressure gauge is accurate? Everything you described points to the baskets/filter filling up with dirt/leaves/other assorted junk. However, in that scenario, the pressure would go high.
    What kind of filter is it? Did you clean out all the baskets and clean/backwash the filter and try the pump again?
    38,303
    Re: Pump Problems
    Did either the skimmer if pump basket get clogged? Did you clean them out and try the pump again?
    Sure you can remove the band and check out the impeller.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Re: Pump Problems
    Sounds like impeller issues.
    Disconnect the power, shut your valves and take the front cover off the pump housing to inspect and clean the impeller. Hopefully the hub and impeller are intact.
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    Jun 2013
    Atlanta GA
    18
    Re: Pump Problems
    This is why I love TFP!
    OK, I'm 98% confident that my guage is working as it's been working over the last few days. Now it reads 0 with no water flowing to the SAND filter.
    I've cleaned out all the baskets. Neither were blocked, but both had stuff in them. (the pool is under oak and sweetgum trees) :/
    I tried backwashing it, but no water flows so that doesn't change anything.
    Tomorrow I'll try removing the front cover off the pump housing. (That's unscrewing that silver band, right?)
    I'll update tomorrow night!
    Pam
