Results 1 to 7 of 7
Thread: Need tricks or suggestion for getting hose onto fitting.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    This is my first year of opening the pool. It was a new install in July. When we closed up the pool, the hose would not pull off of this fitting. We ended up having to cut the hose away. Now I can't get a hose back on it. I'm afraid of breaking the skimmer if I push or pull to hard on it. Do any of you have a trick or suggestion of a way to make it easier for the hose to go on it? Here is a picture. Thanks!
    Attachment 28266
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    38,251
    Re: Need tricks or suggestion for getting hose onto fitting.
    Try heating up the hose with a heat gun or hair dryer.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes those barbs can make things difficult. I've used a little "spit" in the past with things like that. Just make sure you clamp the hose on good before you fire the pump up.
    Jeff
    Boil some water in the microwave. Then stick the hose into it for a moment to get it nice and warm and expanded and wet.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    vegetable oil
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Great suggestions! THANKS!!!
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Tried the hot water idea this morning and it went right on. Thanks again for all the suggestions!!!!
