Results 1 to 8 of 8
Thread: CYA testing
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    CYA testing
    Quick question about water temperature for testing CYA:
    I have seen in several threads where it has been discussed about the low CYA readings in cold pool water. At what temperature does this effect become negligible?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: CYA testing
    you should be good at any reasonable swim temperature, for testing colder pool water let the sample warm up to room temperature before testing.
    38,475
    Re: CYA testing
    It can work at colder water temps, but the reaction is slower so you have to wait longer before actually reading the tube ... easiest to let the water warm up to room temp and do that test last.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: CYA testing
    The reason I asked, is DW really doesn't want pool testing chemicals in the kitchen, no matter how non toxic they are.
    Anyway, it's been too cloudy during the day for a good read, and I'm not sure the work light over my bench would be bright enough (150W halogen work light).
    Thanks for the reply!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: CYA testing
    Don't use the work light for the test. Wait till a good sunny day.
    I'm sure you already know this.
    Jeff
    38,475
    Re: CYA testing
    So, warm up the water inside and then mix and do the test outside.
    All my testing is done in the kitchen and poured into the sink
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: CYA testing
    I can't remember where I read this, but someone said time is the enemy for accurate testing. I think they were referring to pool store testing, though.
    So I am assuming through what you and others have posted here that this is not necessarily true.
    I'm not losing excessive FC through the day, so I think I haven't lost any CYA over the winter, but it would be a good idea to make sure.
    38,475
    Re: CYA testing
    Time is not the enemy for SOME of the tests ... the CH and CYA are not going to change with time (unless you let water evaporate out). The chlorine and pH results will change relatively quickly and thus those should be done right after the sample is taken.
