Thread: Morton Rust Removing Water Softener Pellets
    Jul 2012
    Saugerties, NY
    447
    I was in the store today, and I saw Morton Rust Removing Water Softener Pellets. They say they are 99.8% salt. So what makes them rust removing? Or is this just the magic of marketing? I would imagine there must be some sort of difference between this product and the other water softener salts on the market.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Re: Morton Rust Removing Water Softener Pellets
    They contain a special chemical to prevent rust buildup in a water softener, which we don't recommend adding to the pool. In practice this particular chemical is not a big deal, but always better to avoid any un-needed chemicals to avoid complications.
    Jul 2012
    Saugerties, NY
    447
    I figured it had something added to it, but 99.8% salt is pretty pure so I wasn't sure. I understand not wanting any un-needed chemicals, but could it be beneficial for pools with significant iron issues? I'm curious what the added chemical is.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Citric Acid (<0.5%)
    If you have chlorine in the water, it will use up chlorine and otherwise do more or less nothing.
    Jul 2012
    Saugerties, NY
    447
    So is this kind of similar to a Vitamin C treatment?
    TreeFiter
    Pool Technician
    Saugerties, NY
    Yes, kind of. In a water softener there would be citric acid added constantly, which would help keep iron in solution instead of staining. But in a pool you are doing a one time application without the other steps of an AA treatment, which would use up chlorine and not do much else.
