Results 1 to 7 of 7
Thread: In Floor Pop Ups Not Working
    Apr 2014
    Arizona
    3
    My infloor pop ups are not working at all. Pressure is good and coming out of the holes near the surface fine but none of the pop ups are coming up at all. Any idea what the cause could be?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: In Floor Pop Ups Not Working
    Welcome to TFP!
    If your wall returns (holes near the surface?) are working fine, there probably is a valve somewhere that will direct water to the popups.
    38,235
    Welcome to TFP!!!
    Yup, sounds like a valve is not set correctly. Usually you would likely only get the floor or the wall returns.
    Apr 2014
    Arizona
    3
    Well that was easy enough to fix! Thank you. Wonder why/how the valve got turned off though.
    38,235
    It was probably the Gremlins that MITS and I sent over ...
    What part of AZ you in?
    Apr 2014
    Arizona
    3
    Peoria.
    Sep 2012
    Buckeye, AZ
    10
    Saint what in floor system do you have? Just curious.
