Thread: taylor R0008 was green, now blue?
    I have a taylor test kit for about two years. the instructions for testing total alkalinity say that after putting in 2 drops of r0007
    to then add add 5 drops of r0008. The sample should turn green, and it always has, then add R0009 untill sample turns to red....
    But I needed a new bottle of R0008 and it is blue. I added the 5 drops and the sample turned blue. I then added R0009 and the sample turned to clear...With the green sample...the value for each drop of 0009 was ten. It took about 10 drops of 0009 to turn my blue sample clear...Is the value for the blue solution also ten? This would mean that my total alkanlinity was 100, about what i expected and an acceptable level.
    In other words the blue 0008 turns clear at the same level that the green 0008 turned red....is that correct?
    thanks.
    6600 gal IG concrete/gemcoat
    Fresh water
    1 HP motor
    StayRite PLM 100 system 2 filter
    full sun
    Treasure coast, Florida
    38,281
    Re: taylor R0008 was green, now blue?
    That should still be valid. See the extended testing instructions sticky at the top of this subforum. Is your FC really high?
    30,419
    2 year old reagent is simply not worth keeping. Get new reagent and have confidence in your results.
