Thread: cement wall vs steel wall construction
    Apr 2014
    Philadelphia
    2
    Hello, I am looking for professional advice on if cement wall construction is worth the extra cost for a vinyl liner pool install in the northeast or if it is overkill. Thanks in advance!
    30,415
    Re: cement wall vs steel wall construction
    Welcome to the forum.
    Concrete walls with a vinyl cover (by a professional) is quite unusual (but doable). Is this DIY or are you gonna' have a PB?
    Difference in costs would be minimal, I think. Do you have quotes?
    Jul 2012
    SE Georgia
    91
    My pool is going to be concrete wall with vinyl liner. Where I live, that is what most of the pool companies do. I have seen pictures of the steel walls during a liner change and I would not want my pool to have steel walls. At least not in the high water table area I live in. The pool builder I am using either uses the Polymer walls or Concrete walls on the vinyl pools.
    Apr 2014
    Philadelphia
    2
    The pool builder is Seasonal World in NJ and the cost difference between cement and steel wall is approx $3,000 but includes cement steps with vinyl over instead of steel so the steps are bigger. We will probably spend the extra $ for this! Thank you for the replies!
    Nov 2011
    Moberly,MO
    1,010
    Out of curiosity have you looked into a polymer wall? I have one customer with vinyl over concrete and not impressed with the fit of the liner and concrete. With Ft Wayne polymer you cant get steps covered with vinyl and can customize the step to what you want. That goes for anyLatham polymer kit. I agree with rusty that steel isn't a strong choice. My biggest thinking is we have been doing polymer for around 30 years and it doesn't rot or rust. Have yet to see a panel crack aftr installation. Here in Missouri concrete guys put that in the guarantee that it will crack.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2013
    Central Massachusetts
    174
    There was no premium in my area for concrete so that is what we have. From what I've seen Vinyl covered stairs often don't fit right no matter if the structure underneath is concrete, steel or polymer. Also I don't like how slippery vinyl stairs are. For that reason we went with molded stairs (some may not like that look).
    Liner fit around the rest of our concrete walled pool is flawless, but concrete is what our pool builder does primarily.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
