Thread: dedicated Spa Jet pump, waterway jets
    Oct 2013
    San Diego, CA
    42
    I would like to use 10 waterway poly storm jets in the spa with 10GPM each, so 100GPM.
    According to Hydraulics 101,
    I would need perhaps a 3" suction and 3" return (or 2 2.5" return spa loops)
    It seems I might be at 16' of head, plus pump and jets.
    Hard to figure out jet head loss but I saw a thread that mentioned waterway and said 35' head loss.
    Based on all this it seems like a dedicated 2HP pump might be fine?
    Any reason to go with VF or VS for a spa jet pump?
    Anyone have any experience with the triple jet assemblies from waterway jets?
    O/B Pool: 11,000 gal, 32x15 with baja step, 7ft spa with Waterway jets, Jandy Aqualink RS6 with Pentair IntellifloXF pump. SWG, iAqualink, LED lights, cover-pools auto cover.
    Re: dedicated Spa Jet pump, waterway jets
    The better variable speed pumps use permanent magnet motors, which have a slightly better inherent efficiency than a regular pump, and so save on electrical costs. Since you are in CA, and have high electrical costs that might make a VS worth it if you plan to use the spa quite a lot. The other advantage of a VS pump is that you can dial in exactly how much jet action you want to have. With a single speed pump you just hope you calculated everything correctly.
