Thread: JEP1.5 vs Intelliflo
    Oct 2013
    San Diego, CA
    42
    So I'm going all Jandy, Pool/Spa combo. New build.
    Was really wanting to use the versa-plumb kit to help with space on equipment pad. seems like I might be able to mod it to fit the Intelliflo if I want with that pump over the JEP1.5 ePump.
    Should I still go out of my way to use the Pentair pump vs just sticking with Jandy for the whole setup.
    Note: I will use a separate pump for spa jets so this is just for filtering and future solar heat.
    O/B Pool: 11,000 gal, 32x15 with baja step, 7ft spa with Waterway jets, Jandy Aqualink RS6 with Pentair IntellifloXF pump. SWG, iAqualink, LED lights, cover-pools auto cover.
    38,521
    Re: JEP1.5 vs Intelliflo
    If it is just for filtration and solar, I see no reason you would need the giant 3HP Intelliflo ... the JEP1.5 would probably work well in that situation.
