Thread: Aquapure SWG selection
    Oct 2013
    San Diego, CA
    42
    I'm second guessing my equipment choice. I was going all Jandy and with about 11,500 gallons pool (and spa included). I was going to get the PLC700 (rated to 12,000 gallons).
    Now I read the manual and it mentioned for southern california and warmer areas with longer season to upgrade to 1400 model, but I also read that having a cover you can decrease the power on the SWG due to lack of sunlight. I also have an auto-cover in the works, so I'm thinking the combination of both I can stay with the PLC700 model.
    O/B Pool: 11,000 gal, 32x15 with baja step, 7ft spa with Waterway jets, Jandy Aqualink RS6 with Pentair IntellifloXF pump. SWG, iAqualink, LED lights, cover-pools auto cover.
    Re: Aquapure SWG selection
    An auto cover does greatly cut down on how much chlorine you need. At the same time we always recommend you get a SWG that is larger than you really need. That insures that you can generate enough chlorine without worrying about increasing the pump run time, plus the larger SWG is almost always less expensive in the long run as it will last longer.
    Jun 2011
    Long Beach, CA
    2,790
    With CA electrical rates and extended life of the larger cell I suggest that you get the 1400 cell.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    I would definitely get the 1400. I have 13,500 gallons and in the summer I run my pump 8 hours a day at 60% on my cell. You will have a hard time keeping up with the 700. I think most people don't cover their pools in the summer even with an auto cover. Who wants to look at a cover? If you do plan to keep it covered most of the time, the 700 might just do it.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
